My first welding project - HELLO TIG CART
发表于 2021-8-31 23:46:08 | 显示全部楼层 |阅读模式
Soooo at first, this project was a effing disaster! Then it redeemed itself I found a filing cabinet, and cut it into two drawers. I had it in my head that I wanted to use the cabinet as a base for a cart. Good idea, I thought, until I saw it 'finished.'I couldn't even move it around the garage. It was so low it scraped, the casters were junk, $30 out the window I thought. WRONG! Let's try again...Round two...Put the filing cabinet on the ground where it belongs...And make the REAL cart! The next step is to get some round bar and put some places to hang things Last edited by Taiden; 11-11-2010 at 04:33 PM.
Reply:Good start Taiden.Always remember the 4 F's of quality:If it doesn't effect Fit, Function, or Form:   F@#$ it!!Looks like it'll do the job for ya.Weldtek
Reply:Put a nice rounded edge between the ends sticking out so you don't poke someone in the leg and your done!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by zapsterPut a nice rounded edge between the ends sticking out so you don't poke someone in the leg and your done!...zap!
Reply:better yet, tig some sharp knives on the ends and when someone asks what those are for, well you get the point  you could have used the filing cabinet... build a frame with casters and sit it and the tank on the frame, then the welder on the cabinet.. i was thinking of using a small craftsman 3 drawer tool box for my tig, and still may yet do it yet..  i have a craftsman 3 drawer rollaround, it has the small flip up lid covering the bottom storage space..  was thinking that the flip up door compartment would make a awesome spot for a tig cooler and then the drawers for consumables.. still thinking i might do it...Last edited by brucer; 11-11-2010 at 08:59 PM.
Reply:Originally Posted by bruceryou could have used the filing cabinet... build a frame with casters and sit it and the tank on the frame, then the welder on the cabinet.. i was thinking of using a small craftsman 3 drawer tool box for my tig, and still may yet do it yet..
Reply:So thats what you have been up too Looks good! Neat little cartYa gotta spend money to make money!
Reply:Looks good to me...If I could figure out to post picsID show ya my attempt...Victor O/A SetHF Band SawHomebuilt 16" Abrasive Cutoff SawRed 225 Buzz BoxCraftsman 5hp. 30gal Sears and Robuck LeathDelta 6" Vert. Belt SanderDelta Drill PressGrizzly Band SawBlue EconotigLongevity 50i Plasma
Reply:why narrow the legs together instead of splay outward or parallel?  Seems like it ends up a bit narrower and more tip potential?I like the file cabinet idea as a base structure.. You can cut some holes in the side, mount an HVAC filter, and a walmart box fan for forced clean air into the cabinet, and then let the air out past / through the welder and through a raddiator on the other side of the cabinet as a diy water tig cooler...miller syncrowave 250hobart handler 140home made 400 amp engine driven in progress...
Reply:Originally Posted by jdchmielwhy narrow the legs together instead of splay outward or parallel?  Seems like it ends up a bit narrower and more tip potential?I like the file cabinet idea as a base structure.. You can cut some holes in the side, mount an HVAC filter, and a walmart box fan for forced clean air into the cabinet, and then let the air out past / through the welder and through a raddiator on the other side of the cabinet as a diy water tig cooler...
Reply:Originally Posted by samsberrLooks good to me...If I could figure out to post picsID show ya my attempt...
Reply:You might consider widening the wheel stance.
Reply:Did you leave room for a bigger bottle?http://www.facebook.com/profile.php?id=100000825140116 Lincoln Weldanpower Model # AC-225/DC-210/6 portable,LN-25 suitcase feeder,Harbor Freight 80 AMP Inverter DC Tig
GMT+8, 2025-12-25 02:14 , Processed in 0.093863 second(s), 18 queries .
