my last job
发表于 2021-8-31 23:46:07 | 显示全部楼层 |阅读模式
Spiral is made out of aluminum and powder coated gloss black. The hand rails are steel. Attached Images
Reply:Purdy!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Thanks
Reply:nice work what did you use to bend the stairs
Reply:If you are talking about the hand rail I used a RM 30 ring roler.
Reply:what is a rm 30 ring roller
Reply:looks good, Is it bolted or welded together.Annamel TW9Y Georgia
Reply:It is made by Baileigh. Attached Images
Reply:Originally Posted by Annamellooks good, Is it bolted or welded together.
Reply:Fantastic workA butterfly without wings, is just an ugly bug
Reply:That is very nice.  How did you lay out the helix pattern of the steps?Lincoln ranger 305gVictor torches Oxy/Propylene Jackson Halo nexgenWilton ViseJet Bench GrinderKennedy Tool Box setAnd The Most Valuable Of AllA Tenacious Thirst For KnowledgeBuild Heavy Haul Light!
Reply:very nice!!Ya gotta spend money to make money!
Reply:Man that's complex!I think I'm a hero when I cut a straight angle that fits"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I think he may have had equally spaced holes in the steps where the pickets went in, then the last one on each step would go through the next step up to the rail, if that makes sence. hard to tell if thats what he did but thats what i doNothing Ever Got Done By Quitting, Never Give Up.
Reply:VERY Nice even down to the powder coatCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Nice piece of work indeed.Do you have an attachement for your bender just to make spiral hand rails?
Reply:Man that is nice! I want to build one for my log house, are there any prints for these or do ya just guess and by gosh it?
Reply:Originally Posted by mattw90That is very nice.  How did you lay out the helix pattern of the steps?
Reply:Originally Posted by JoeDNice piece of work indeed.Do you have an attachement for your bender just to make spiral hand rails?
Reply:Great job. Around here it is 6'8" head room clearance.11b I posted a link in the thread on "calculate stairs".  It will provide some construction detail. However, as SML explained headroom and clocking is very important.
Reply:Originally Posted by SML WelderLet me try to explane. Take a clock for example and devide 360 into 12 =30 so you need to have a 30 degrie tread. that will make as you walk onto the 9th tread you are going under the platform on top. you need to also make the distance there no less than 6'6" to pass code. so we have all of our treads cut out and ready to go. We dont put holes in th treads every thing is welded to the side of the tread. To get the rise right you devided the floor to floor hight by how many treads you want. for what works best for the job site. you go back to the clock example and that will tell you where your last tread is going to be.I am not very good at explaning things very well but maby that helped. The very first one that we ever made turned out good but it sucked to build. But every time it gets better.Thank you all for the kind words.
Reply:Beautiful!America Needs AMERICA'S Oil!!!"Global warming is the greatest scam in history ...There is no run away climate change. The impact of humans on climate is not catastrophic. Our planet is not in peril."--John Coleman, Founder of The Weather Channel
Reply:great job!
Reply:Looks great!
Reply:SML Welder - Putting aside the caliber of the work, you don't powder-coat anyoutside work gloss black, and you have to be most judicious on interior works.  Guaranteed, your stairs showed all the dust it picked up on the road, on it delivery run.  Gloss black shows every finger print, every raindrop, all the dust in the air, and every scratch.  Unless these stairs are feather dusted daily, they cannot maintain their look.  Go with black only if the client absolutely insists.  Powder-coater's, typically, don't market their services well with respect to aesthetics.         Black is available in multiple values from matte to at least 90% gloss.  The lower gloss levels look good longer outside without maintenance than high gloss.   OPUS
GMT+8, 2025-12-25 02:14 , Processed in 0.077409 second(s), 18 queries .
