Sandblasting before welding
发表于 2021-8-31 23:46:03 | 显示全部楼层 |阅读模式
I've always sandblasted my parts before tig welding. A welding salesmen was telling me that it contaminates the weld. I've never had any problems. Who's right?
Reply:sand blast then prep with alcohol or acetone  only real is issue is if you blast steel and stainless with the same media it will embed the steel in the stainless and will rustMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Aluminum+Sand+TIG do not mix....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I have done it but was for equipment that has been sitting a long time rusting and needed a lot of work replacing wear panels and parts patching water trucks and pulls But that's stick and fcaw work on steelBut it is much faster than wire brushes on any grinder any day just have to blow out the abrasive when doneI have cleaned broken aluminium parts in a bead blast cabinet before zap never had a problemLast edited by killdozerd11; 08-06-2012 at 11:32 PM.Backed my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:That salesman probably wants to sell you grinding wheels and flap disks.  Sandblasting is great, especially if you want minimum disturbance to the surfaces surrounding the weld (other than making those surfaces a little rougher).  Sandblasting is not going to remove material as aggressively as a grinding wheel or flap disk and will prep nice and uniformly without having to be super-careful.  As other have said, just be sure to remove any media/dust from the parts before welding.
Reply:It would depend on the material and the blasting media.I've had to TIG steel, on parts that have been sandblasted for my powdercoater, to make small repairs before coating, and it was pretty rough, lots of contamination. How much surface are you blasting and welding? Sandblasting would be one of the last prep methods I'd choose because of the setup and equipment required. A grinder with a wire wheel is pretty easy.Ian TannerKawasaki KX450 and many other fine tools
Reply:I often get plasma Cut parts which have been sandblasted, Welds perfectly well for me
Reply:Originally Posted by BrianstickI've always sandblasted my parts before tig welding. A welding salesmen was telling me that it contaminates the weld. I've never had any problems. Who's right?
Reply:If you are the welder don't seek advice from a "Salesman". The generally have lots of catalog time and little field time."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Originally Posted by zapsterAluminum+Sand+TIG do not mix....zap!
Reply:Originally Posted by BrianstickI'm talking about small steel parts that need to be welded. I've been doing it for years,
Reply:By far sandblasting is my favorite prep method, hands down...Last edited by kustomizingkid; 08-07-2012 at 09:11 PM.
Reply:Originally Posted by kustomizingkidBy far sandblasting is my favorite prep method, hands down...
Reply:Originally Posted by zapsterWhat is all that black soot from if it is so clean?...zap!
Reply:there is always soda blasting without the sand and gets close to the same outcome.
GMT+8, 2025-12-25 04:02 , Processed in 0.097146 second(s), 18 queries .
