Looking For Aluminum Welder In CT
发表于 2021-8-31 23:45:58 | 显示全部楼层 |阅读模式
Not sure where to post this, but feel free to move as you desire.I am looking for someone to weld .190 thickness aluminum  for a new project I have.I am located in New Haven County, Connecticut.Anyone interested in quoting the job?  It's all 1.5"x3" Rect 6061.   Can be tigged or migged.Please send inquiries to [email protected]!
Reply:I am in Mass if you have no takers..What is the job?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Basically I bought a Truck Craft aluminum dumping flatbed.I need a frame constructed to fit into the stake pockets of the bed.  It will be 5' high x 9' long square sides, a few lengths (7') welded to the top, and a small front section.Last time I built something like this I cut all the material, and provided a detailed drawing.  Fit like a glove.The sides will be installed by me on the inside of the framework.It's sorta something like the picture below, but with no removable top, and simple tailgate.Also is attached is a steel frame I had built for the current body, we can say it's almost duplicated that frame work, just a couple more uprights to fit into the stake pockets.All material will be cut.How far are you from 06478, your work looks amazing.I'm not against driving a bit, if your not against ball parking it. Attached ImagesLast edited by brendonv; 08-09-2012 at 09:23 PM.
Reply:Fairfield here.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:HI Tj,  I remember you.You've done some work for me in the past.  I am Eric's brother, (he owned LMMC-CT).Last edited by brendonv; 08-09-2012 at 10:29 PM.
GMT+8, 2025-12-25 02:14 , Processed in 0.094458 second(s), 18 queries .
