$150 Table Find
发表于 2021-8-31 23:45:51 | 显示全部楼层 |阅读模式
I found this baby at an estate sale for $150It has a solid plate under it as well.Over all thicknessK.I.S.S evading the minds of engineers since the beginning of time.Lincoln Precision Tig 225Lincoln IdealArc 250Lincoln Ranger 305GLincoln SP 185
Reply:Holy Shiz-Nazz !That's a LOT of table....  Nice Score!Miller Diversion 165120 amp Buzz BoxVictor Oxy/Ace Oxy/LPGSmith "Little" Oxy/LPGHypertherm Powermax 30Lot's of Misc. tools n' crap....
Reply:That table should last til your great great great grandchildren learn to weld. Very Nice!
Reply:WOW!!!! great find!
Reply:Killer.......thats a great buy.Lots of toys.
Reply:WOW great find! That thing must weigh a ton.
Reply:Very nice! How much does that sucker weigh?
Reply:So that's where all the kool old welding  tables R, Arkansas, sheesh go figure.   Ok, $150 I'll buy that and then how much for the four friends who helped you move itvery keen indeed!Lincoln Power MIG 215Lincoln WeldPak 3200HDLincon ProCut 25Lincoln WeldanPower 225 AC/DCIf all else fails... buy more tools
Reply:man it seems like there are lots of lucky finders on this site. i look and look for things and never seem to stumble across great deals. It seems like everyone here in wisconsin knows what they have and the value of what it is even as scrap.
Reply:4 guys???? more like 6 or 8.....How did ya move that thing around, Hay i got a forklift for sale....
Reply:Is it cast iron or steel?  How much of it is hollow and how thick it the plate?You got a great deal.  I wonder what it was originally used for.Jack OlsenMy garage website
Reply:Originally Posted by barefooter14man it seems like there are lots of lucky finders on this site. i look and look for things and never seem to stumble across great deals. It seems like everyone here in wisconsin knows what they have and the value of what it is even as scrap.
Reply:Originally Posted by WeldingMachineHit the local scrap yards, there is neat **** everywhere!
Reply:I really lucked up on this sucker no body was really buying scrap at this auction and this was the next to the last item sold so most of the window shoppers had long since left.To answer  a few questions about the table it is mild steel with what appears to be a surface ground finish on the top.  It is completely level across the top, I think we drug out every single level in the shop and on our truck to check it.As far as 4-6 guys moving it  I went to unload it with the 90hp Kubota with wheel weights and water in the tires and it cleared the rear tires.  I had to go out to the hay lot and get a 5x5 roll of hay for a counterweight and even then I was only able to moving using the front tires.Being that it is 7/8 in plate(~35.7 lbs/square ft) on top and bottom and it is 4ft x 8ft I would say conservatively it weighs around 2500 lbs. Not to mention the frame between the plates are 3/8 in thick channel iron.K.I.S.S evading the minds of engineers since the beginning of time.Lincoln Precision Tig 225Lincoln IdealArc 250Lincoln Ranger 305GLincoln SP 185
Reply:Not to thread hijack, but I love it! You work your tractor like I do. I periodically will use the outriggers on the backhoe to lift the rear tires of the tractor up in the air as I keep the forks in contact with the bottom of a skid. Then extend the backhoe out to full reach and let the outriggers out. Using the weight of the tractor to do the lifting and the hydraulics to do the holding.  The real killer is the weight being too far out from the pin. At the pin I can pretty easily pick up 3600 pounds with my little 39 HP John Deere 4500. But in the same configuration I can't pick up a 330 gallon tote / IBC full of water and weighing ~2500 pounds.-Jim
Reply:Nice score! LA_Backwoods,Actually you're one torch cut away from having bought two 4x8x7/8 tables. Good Luck
Reply:Super score!!!!I like your K.I.S.S. tag line. I need that as a tattoo200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
GMT+8, 2025-12-25 02:18 , Processed in 0.073319 second(s), 18 queries .
