Floating Stairs
发表于 2021-8-31 23:45:49 | 显示全部楼层 |阅读模式
I'm working on a site and need to build 6 sets of single stringer floating steps.  The tube will be 4x6 and the risers will cut from the same material.  I have done these in the past, but in place which makes the calculating a little easier.Does anybody know of software, or an easier "trick" to layout the stringer?Thanks,CR
Reply:Max rise should be <=8". run of 11". We need total rise and total run. I am assuming the stringer to be in the center with other 4x6 pcs coped into it? And a bigger tread added to that? Or is the stringer only on one end?
Reply:Yes, 4x6 centered, and coped 4x6 risers.  I understand how to calculate stringers, but mono stringers are a bit different.  The risers are built up from the stringer as opposed to a standard double stringer where the top edge of the channel is the nose of the tread. CR
GMT+8, 2025-12-25 02:18 , Processed in 0.164597 second(s), 18 queries .
