A very unique welding table
发表于 2021-8-31 23:45:47 | 显示全部楼层 |阅读模式
I aquired this from a fellow who was selling out his shop and thought you may enjoy seeing it. Its recycling at its best. He had this faceplate from a lathe he no longer had and drilled six holes in it, added three legs which didn't hurt the faceplate, to make this table. It can still be used as a faceplate as it still has the D-mount pins. The weight makes it very stable. And it maxes out at 760 RPMs,  sorry about that, I couldn't resist. Attached Images
Reply:Now that's an interesting idea! Being cast iron weld berries won't stick to it. Now put a gear motor on it and you'll have a great rotary table.
Reply:Originally Posted by forhireNow that's an interesting idea! Being cast iron weld berries won't stick to it. Now put a gear motor on it and you'll have a great rotary table.
Reply:That thing must weight a ton!
Reply:My 1st thought was " What a cool patio table!" .No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I knew this would invoke some interesting comments and it did. Still, its a pretty cool table. Thanks for your comments.
Reply:Wow heavy table and could still go back on lathe without much trouble great idea "MAX USE OF TOOLS"  Would like to see the belt sander on the right with red wheel.                                                            VernonHomemade Belt Sander "LINK"http://s795.photobucket.com/albums/y...Belt%20Sander/
Reply:That table just screams positioner!    Throw some plastic over it and you could even throw ceramics. City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by 1969 VernonWow heavy table and could still go back on lathe without much trouble great idea "MAX USE OF TOOLS"  Would like to see the belt sander on the right with red wheel.                                                            Vernon
Reply:that's one expensive faceplate to use as a welding table...but what works works.  I wouldn't expect to find one of those for cheap anywhere.Nice KMG clone.  If you need any contact wheels, platens, guide/drive wheels, etc... go to http://beaumontmetalworks.com/.  Rob (the owner) is a really good guy.  He's the one who pretty much invented that grinder model.--Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:Originally Posted by wintermutethat's one expensive faceplate to use as a welding table...but what works works.  I wouldn't expect to find one of those for cheap anywhere.Nice KMG clone.  If you need any contact wheels, platens, guide/drive wheels, etc... go to http://beaumontmetalworks.com/.  Rob (the owner) is a really good guy.  He's the one who pretty much invented that grinder model.--Wintermute
GMT+8, 2025-12-25 02:18 , Processed in 0.111868 second(s), 18 queries .
