20" Smoker
发表于 2021-8-31 23:45:46 | 显示全部楼层 |阅读模式
Pipe is 20" by 49" and the box is 20"x20" Box is 5/16 and the main chamber is 1/4". The legs look short because i am going to add a angle straigt now. Then attaching a frame for a small trailer and axle. PIC ON THE WELD PLEASE TELL ME WHAT I NEED TO DO TO MAKE IT LOOK BETTER.
Reply:Info on your rod and settings would help..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:bead looks a little cold.. to make it really look better get some heat in there, put in 20 pounds of ribs and give me a call...
Reply:grinder?handler 187hobart air-force 625one old azz lincon cracker box
Reply:I have seen pits with the welds should i grind it all down?
GMT+8, 2025-12-25 02:15 , Processed in 0.109313 second(s), 18 queries .
