Stainless Steel Hose Holder
发表于 2021-8-31 23:45:46 | 显示全部楼层 |阅读模式
Todays project was a stainless steel hose holder for a garden hose. Material:1/8'' 316l stainless1/16'' 316l fillerAround 80 amps Scratch start only3/32 red#7 cupOn to the build....The materialLayout for score marks to bend. I also sanded it with 180 grit on a plam sander to give it a smooth finishScored with the cutoff wheel. Now it will bend easier and straightPut it in the vise and bend awayBending all doneYa gotta spend money to make money!
Reply:Bends all welded up. Welds could have used alittle better gas coverage, but i did not have a gas lens on. Lay the wire in the grove and weld away The mounting tab/ holder tab. YUP! thats a harbor freight grinder. I picked it up today for only $10.00. It works pretty good for 10.00, it wil NEVER replace my good old milwaukee grinder though.Mounting tab holes layoutAll welded upDone!Thanks for lookingShaneYa gotta spend money to make money!
Reply:Great idea! I dont know how many of the $1 ones I have broke off. I need to build one!You have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
Reply:Very nice!!! Looks like a great place to hang the leads, just mite have to steel this one!SA 200square wave 175 proairco 250airco dip pacsouth bend lathemilling machine
Reply:A possible alternative to the expense of shop built is below.SS, 5/16" ID mount holes--sturdy, will hold 50' of 3/4", water filledgarden hose. I use these in commercial installs--ustah make my own.McMaster Carr   53325K33       $ 27.71http://weldingweb.com/attachment.php...1&d=1290632638http://weldingweb.com/attachment.php...1&d=1290632648 Attached ImagesBlackbird
Reply:Originally Posted by dave powelsonA possible alternative to the expense of shop built is below.SS, 5/16" ID mount holes--sturdy, will hold 50' of 3/4", water filledgarden hose. I use these in commercial installs--ustah make my own.McMaster Carr   53325K33       $ 27.71http://weldingweb.com/attachment.php...1&d=1290632638http://weldingweb.com/attachment.php...1&d=1290632648
Reply:Nice job Shane...Now the rest of you guys.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by weldbeadwith all due respect, this item cannot be compared to what OP built  which  provides a curved smooth support for whatever gets stored on it. the  manufactured  device shown will cause a hose to kink and crack in short order because of the pointload. my fotos attached show how i provided the same support for some expensive welding leads..sections of 10 " pipe.
Reply:I'd hang a garden hose on that!...if I had my own place and...a garden!
GMT+8, 2025-12-25 07:28 , Processed in 0.112707 second(s), 18 queries .
