Can i run a digipulse feeder of a heliarc 252 power source?
发表于 2021-8-31 16:58:49 | 显示全部楼层 |阅读模式
Hello this is my first postMy name is Richi have a heliarc 252 power source. can i run a digipulse feeder off that?thanks
Reply:I'm going to say no you can't. You could probably run a voltage sensing feeder off it though.Thermal Arc 320SP ( Lorch )Cobra PythonsThermal Arc 300 AC/DC  ( Sanrex )ESAB 301i AC/DC  ( Lorch )Thermal Arc 161STL  ( WTL )Thermal Arc 190S  ( Sanrex )Cut Master 82, 42. Cut45 ( WTL )Victor Gas Apps.Boxes and boxes of welding crap.
Reply:You have to post spec on both.Most likely it work just find.Most wire feeders use 120v acThe only time you can run problems is with spool guns most are 24v ac.Dave  Originally Posted by Lectrician10Hello this is my first postMy name is Richi have a heliarc 252 power source. can i run a digipulse feeder off that?thanks
Reply:Most wire feeders are 24 volt, and 42 volt.. Older ones were 120 volts.. The 252 is a cc only machine, and it will take a LN-25 type voltage sensing feeder to run of the stick mode in DC output..No CV output from the power supply.The Digipulse is for a CV power supply.Last edited by Brand X; 12-05-2020 at 11:18 PM.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:The digipulse wire feeder is a microprocessor controlled feeder and it will control the SVI 450i welder. ESAB or L-Tec and allows for pulse welding. In its day it built a lot of car frames.The heliarc 252 Is a TIG / stick welder. The two can not be adapted together and work.
GMT+8, 2025-12-19 00:38 , Processed in 0.104922 second(s), 18 queries .
