Building a Trellis
发表于 2021-8-31 23:45:34 | 显示全部楼层 |阅读模式
http://community.webshots.com/user/H...host=community Here is a link to Webshots and a photo album onmy building a Trellis for my Purgola. It is still a work in progressHarold MulderMiller 211 AutosetHTP 201 Invertig with water coolerHardinge Cataract Quick Change Lathe
Reply:Nice job. What size material are you using?
Reply:I like your custom bender. That cut out for the c-clamp is nice. Of course the project itself looks good, too. I'll want to see the completion pictures.
Reply:Thanks once finished the pictures will be up. This might take a few weeks depending on work and weather. Majority of pieces are made with 1/4 by1"flat bar and then I used 1 by 2""tubing 1/8"wall for  the bottom and top bar once installed and all the little support pieces between the 6 sections. One good thing I've noticed is that as the piece progresses my Tig welding shows some improvement.Harold MulderMiller 211 AutosetHTP 201 Invertig with water coolerHardinge Cataract Quick Change Lathe
Reply:Nice project!! Good to see a fellow plywood bender! I too like the cut out for the clamp.200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:http://community.webshots.com/album/...host=community  Added a few more pictures of the project. Hope to have the final shots up by next weekHarold MulderMiller 211 AutosetHTP 201 Invertig with water coolerHardinge Cataract Quick Change Lathe
Reply:Originally Posted by haroldmulderhttp://community.webshots.com/album/...host=community  Added a few more pictures of the project. Hope to have the final shots up by next week
Reply:http://community.webshots.com/user/H...host=community Well the project is finished you can check out the last view photos at the link above.Harold MulderMiller 211 AutosetHTP 201 Invertig with water coolerHardinge Cataract Quick Change Lathe
Reply:Super nice project and job. . . . but you installed the bench the wrong way.  MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-25 02:15 , Processed in 0.098626 second(s), 18 queries .
