lincoln ranger 9. 1998.
发表于 2021-8-31 23:45:30 | 显示全部楼层 |阅读模式
i have a ranger 9 welder . i have 53 volts coming out of the 110 volt outlets and a little spark at the welding rod. i thought i blew a wire off while blowing out the dust. looks like all connnected. can someone help me?
Reply:Sounds as if you may be getting only flashing voltage (+/- 12VDC) at the rotor brushes or the slip rings are dirty/tarnished.Clean the slip rings with fine sandpaper (320grit) and check the DC voltage at rotor brush leads #219A (-) and 200A (+) with Fine Current control set to maximum and engine running at weld speed.  DC voltage should be between 40-50 volts.Did you just get the machine or did it just start producing low output?Got a unit code number?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:i bought it 2 weeks ago and had been welding great. took the covers off, paint them blew out dust. the one thing i am concerned with is the small cover by the oil filter has a small aluminun square bracket of some sort. it has three wires  hooked to it on the back side. what it that?
Reply:it is a pg218g-i 11423h.
Reply:Originally Posted by sirweldalotthe one thing i am concerned with is the small cover by the oil filter has a small aluminun square bracket of some sort. it has three wires  hooked to it on the back side. what it that?
Reply:the no. i see are.........10539-u1980516171. i cleaned the slip rings and brush's. worked great. put covers on and low volts/no low arc again. cleaned them again and still nothing. has to be something simple.
Reply:The 10539 is the code number that brings up this manual.http://www.lincolnelectric.com/asset...oln3/im511.pdfDid you check DC voltage at the brush leads when it had low output?Did you pull all the harness plugs - especially at the control board - and check for corroded or poor connections?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:ever now and then mine will stop generating, and if I click the switch  (welding terminals remotly controled) a few times it will usaly come on, when I got it that switch was replaced, and some times jsut cycling the other contorls (my guess is dirty contacts some where),
Reply:thanks farmer boy.
Reply:i had it loaded for the repair shop. wanted to try farmerboys deal. and i cycled the switch's, fine tuning knob. and it is welding again. so unloaded it.lol. thanks farmerboy and duaneb55. great job.
Reply:farmerboy.Glad to hear she's running right again sirweldalot.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:thanks. can you put pics on here? i'm new to this site.
Reply:Yep.http://weldingweb.com/vbb/showthread.php?t=111MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:some of the smokers/grills i have made. Attached Images
Reply:another smoker.
Reply:another one.
Reply:Glad you got it working
GMT+8, 2025-12-25 04:13 , Processed in 0.090710 second(s), 18 queries .
