miller discovery
发表于 2021-8-31 23:45:30 | 显示全部楼层 |阅读模式
Well guys I have found out that the miller millermatic 252 does not like a 44 pound spool of .35 steel wire coated in break fluid.......the reason we put it in the welder is because it was the only spool we had. Attached Images
Reply:obviously? that just spells disaster not only for your health but for your weld. Sure hope you didnt breathe any of those fumes
Reply:No it would barley feed the wire so you couldnt weld with it but problem sovled new wire.
Reply:Well Hmpoh!, Why don't you just let me come and take that piece of junk machine off your hands then!
Reply:It works now with new wire .
GMT+8, 2025-12-25 04:13 , Processed in 0.066994 second(s), 18 queries .
