Miller 150 STL
发表于 2021-8-31 23:45:30 | 显示全部楼层 |阅读模式
I have used this machine quite a bit in the field, mostly for TIG of stainless and 1/16" s.s. rod. But I have a job coming up that is to welding 3/8" x 4" flatbar (extending a few ladders). I think I can run 3/32 7018 hot enough to do the job, but I'm wondering if anyone has run into duty cycle issues.-MikeCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Are you planning on 110v or 220v?  Run 3/32 about 90 amps +/-.  If running on 220v don't worry about it.  Mine will eat as much 1/8" as I can feed it on 220v.My name's not Jim....
Reply:ya at 90 amps or there about you shouldnt have any problems with the duty cycle
GMT+8, 2025-12-25 02:15 , Processed in 0.072518 second(s), 18 queries .
