high pressure weld
发表于 2021-8-31 23:45:30 | 显示全部楼层 |阅读模式
I was given a 1 " high presuure steel hyd . line to repair , has small leaks at welded joint s at block where all three connect . looks like silver solder . can this be resolderd or brazed ??What would be best method?                                       Thanks Larry
Reply:Short answer is yesMiller bobcat 225g  - spoolmatic 1Mm250 - 30a spoolMiller spectrum 375Thermal arc 95 Everlast Ex 250As the boiler turns, these are the days of our lives
Reply:Can't you just tig it?Welding/Fab Pics: www.UtahWeld.com
Reply:I've tigged them before.Miller bobcat 225g  - spoolmatic 1Mm250 - 30a spoolMiller spectrum 375Thermal arc 95 Everlast Ex 250As the boiler turns, these are the days of our lives
Reply:Clean it up good, and tig it. I do a couple every week.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Theres a picture in the my gallery , cant seem to get it to paste ??         Can i oxy acetylene weld ?? Don,t own a tig .                            Thanks larry Attached Images
Reply:I've fixed hundreds of similar pieces like that over the years.  Don't try to gas weld it,,,,,you will be doing it again if you do.  Clean it up really good and use stainless, 309 works well, so does 307, just depends on what I have at the time.  If you use 7018, it will crack after a few hours in service, the stainless is more maleable.  One more very important thing to consider is, why did it break?  Make SURE the clamps that hold the pipes are in place and tight, this is the most common cause of that kind of failure, youcan weld it up a dozen times and it will break a dozen times if its not secured properly.--Matt6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:Matt    thanks for the reply . I would have to remove all the silver solder . would be concerned that the line would not be in same original position after welding and repositining ??                            Thanks larry
Reply:From your picture it does not appear to be silver solder. If it were silver the pipe would be in a socket in th block and all you would see of the silver is a fine line in the joint. In the pic it looks like there is build up on the block and pipe. I would grind the weld out except for a couple of "tacks"   then weld with 309 as Expat recommended. If you are still worried about it moving tack the block to the table and clamp or tack the other ends to bracing off the table.
Reply:If it is soldered already, which it shouldnt be if its OEM, then just re silver solder it.  It looks like it's off a piece of CAT or Case equipment and those are USUALLY not soldered, they are welded.6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:I've worked around and under that stuff for thirty years and repaired a lot of hyd. lines like that and have always brazed them up and never had one leak yet.What ExpatWelder said about the clamps. Almost everyone I've fixed was because someone thought it would be quickest to leave the clamps off and the vibration goes to work.Trailblazer 302Hobart Stickmate AC/DCLincoln SP 135 TSmith torchSpoolmatic 30A
Reply:Thanks     All the info is much appreciated cool:                                   Laruance
Reply:Originally Posted by shortarcI've worked around and under that stuff for thirty years and repaired a lot of hyd. lines like that and have always brazed them up and never had one leak yet.What ExpatWelder said about the clamps. Almost everyone I've fixed was because someone thought it would be quickest to leave the clamps off and the vibration goes to work.
Reply:Larry O       Thanks for your input . That is what I did ground it back and brazed it . capped thends and put100 psi into it. No leaks        laurance
GMT+8, 2025-12-25 02:15 , Processed in 0.090432 second(s), 18 queries .
