Structual AWS D.1.1 certification questions
发表于 2021-8-31 23:45:29 | 显示全部楼层 |阅读模式
My class is going towards getting this certification. Some students have uncovered different certification specs. Main question is this: While piece remains tacked, can you use a grinder / wire wheel on your weld?
Reply:I am not sure what D.1.1 saws about that. I know through my union we are not allowed to use any powered tools to clean the coupon not even a wire wheel. I also know that in MA and CT you are not allowed to use power tools to take a DOT test.Honestly if you clean well with good sharp chipping hammer and a wire brush you should be good. I always bring a small and large wire brush, a scratching awl, sharp chipping hammer and a small and sharp chisel and a small ball peen hammer to use with the chisel. No need for power tools to pass this test.
Reply:Yes,   as per AWS D1.1 you can use any powered tool you choose.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Around here in addition to a AWS cert you need a WABO ( state of washington ) cert. for structural steel.  The AWS and wabo are generally the same test except no grinding on the root or the cover pass. Additionally any grind marks outside the groove are a bust. So most local testers do NOT let you use grinders on the test, except pipe tests.The other requirement is the machine needs to zero'd out so you know how to set it up.My thought is your in trouble if you need a grinder on a test, and need more practice.
Reply:A tool you can use, is a small sharp chisel, or a file ground sharp. I find that the chisel stays sharper than a chipping hammer and a couple of quick swipes is all you need to clean off/out your weld.
Reply:If I have to take a no grind test I have a nice big pipeliner file modified just for the purpose.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:If you think you need a grinder your not ready for the test .
Reply:Originally Posted by TozziWeldingIf I have to take a no grind test I have a nice big pipeliner file modified just for the purpose.
GMT+8, 2025-12-25 02:16 , Processed in 0.104952 second(s), 18 queries .
