Repair on 5ft 3point J.D rototiller
发表于 2021-8-31 23:45:29 | 显示全部楼层 |阅读模式
I will be useing a miller Bobcat 250 portable stick welder on this as thats all I have. I welded this once about 5 yrs ago with 7014 and it has cracked through the welds which are at the base of the gear box mounting bracket. The welds where it cracked again are only about 3" long. The tiller frame is about 1/8" thick, is there a better rod than 7014 I should use thanks?
Reply:v out the old, weld up with 7018. Use gussets if necc
Reply:Pics would helpBut 7018 is a better rod for repair workBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Thanks I will give it a go.
GMT+8, 2025-12-25 02:15 , Processed in 0.104341 second(s), 18 queries .
