D1.1 diagrams
发表于 2021-8-31 23:45:29 | 显示全部楼层 |阅读模式
I've been poking around on the AWS website trying to find the specs for D1.1 unlimited.  A contractor that gave me a call said they need me to carry the NYS DOT 4G card in addition to my 3G card.I burned on 3/4" plate when I took my 3G and 4G D1.1.  I figure I'll burn a D1.1 unlimited on 1" plate while I'm at it between passes, but I can't remember if the setup requires 3"x7" plates with a 22.5 degree bevel and 1/4" root, or if the qualification procedures allow using beveled plates that are wider than 3 inches.I have a pretty good lead on some 1" scrap steel for 60 cents a pound, and I just want to make sure this stuff will do the trick before I buy it.  Anyone know a good link to the part of the code I need?
Reply:http://www.nyc.gov/html/dob/download...lder_guide.pdf requirements for NYC DOTwhen i tested aws d1.1 for LA City Structural for SMAW it was 2 6x6x1 plates with 22.5 bevel 1/4 inch root opening with a 1/4 inch thick backing barMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Yeah, I did a call out on Long Island and hauled my job trailer down there with me.  I figured the job was worth it, until I got butt-raped going across the GW and Throgs Neck... 4 axles, both bridges came to $47.I should have just gone down the bronx river parkway and taken my chances with the commercial plates.
GMT+8, 2025-12-25 02:15 , Processed in 0.079767 second(s), 18 queries .
