6G GMAW Cert Test
发表于 2021-8-31 23:45:29 | 显示全部楼层 |阅读模式
I have to take my 6G today and I'm super nervous. I'll be taking the test with .035 and 75/25. Is there a ball park v/a setting that you might suggest for a good root pass. Any tips or tricks sincerely appreciated. I've scoured the internet and most advice is on stick! Thanks!
Reply:What code will you be certifying to?Thanks,HoboLincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
Reply:Have you been practicing? If so,don't try anything new on your test.
Reply:ASME. And it will all be uphill.
Reply:If its 6G then how can it be uphill? Well, some of it yes. But some of down, flat, etc.Short circuit GMAW for ASME pressure pipe? Are you sure?EricAWS D1.1 Certified SMAW 3G Unlimited, Open Root                             FCAW-G 3G Unlimited, w/BackerCellular Tower Reinforcement Welding on the frozen tundra of the greater Mid-West
Reply:Originally Posted by Welding_SwedeIf its 6G then how can it be uphill? Well, some of it yes. But some of down, flat, etc.Short circuit GMAW for ASME pressure pipe? Are you sure?Eric
GMT+8, 2025-12-25 02:15 , Processed in 0.100712 second(s), 18 queries .
