Welding to cast aluminum
发表于 2021-8-31 23:45:26 | 显示全部楼层 |阅读模式
Anything I need to worry about when welding to cast aluminum (like you would with cast iron)?I assume I am ok to weld directly to it without any issues like I would with cast steel (not cast iron)?The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:You planning on using your mig?Clean it, bevel it, and use 4043 and you should have reasonable success.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Yes, mig is all I have.The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man"  Moses 1:39Link: My name is John, and I am a member of The Church of Jesus Christ of Latter-Day Saints.-- ColdCreekWorks.com --
Reply:Preheat. Preheat. Preheat.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:X2 on the preheat. Also clean it VERY WELL and then clean it again. Good luck
GMT+8, 2025-12-25 04:02 , Processed in 0.091436 second(s), 18 queries .
