what tungsten to use
发表于 2021-8-31 23:45:22 | 显示全部楼层 |阅读模式
this may help Attached Images
Reply:Ed,Everything I have says don't use pure green with inverters.  I have seen basketballs on the end of those green tungstens with an inverter.Also,You forgot ZirconiatedEsab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I have an inverter, all I use (for everything) is 2% Thoriated."SOUTHPAW" A wise person learns from another persons mistakes;A smart person learns from their own mistakes;But, a stupid person.............never learns.
Reply:That chart is circa 1963 technology. Even a Synchro 250 will weld bitchin' on aluminum with 2% thoriated.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:it may be old but it still the samei all ways use 2% thoriated even on alum.untill i bought my Dynasty 200 (inverter)i still use 2% thor on steel and stainless steelon the 200 but the 2% ceriaed does workbetter with a inverter on alum. i have a lot oftungsten and did not want to buy more but i tryed the 2% ceriaed on alum. it does makea diff. with alum. and a inverter welder Attached ImagesLast edited by ed mac; 07-16-2009 at 09:00 PM.
Reply:Thanks for the tip, I will definitely give it a try. This is not the first time I've heard that 2% ceriated holds up & works better on alum.
Reply:My favorite all around is lanthanated.1.5 or 2%. Restarts using ceriated is not as reliable as lanthanated.Seems I have to keep grinding the ceriated to get reliable starts. Lanthanated and thoriated restart much easier. And they work fine on alum also.just my observations.mm135HTP Invertig 201 With water cooler9" Southbend LatheLots of hand tools.
Reply:I've tried to use pure tungsten on steel and it doesn't workthoriated works finenow I ordered a box of lanthanated
Reply:LMAO,Just thought it funny that you store your tungsten along with the cat food.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:Originally Posted by papasloanMy favorite all around is lanthanated.1.5 or 2%. Restarts using ceriated is not as reliable as lanthanated.Seems I have to keep grinding the ceriated to get reliable starts. Lanthanated and thoriated restart much easier. And they work fine on alum also.just my observations.
Reply:I run red end tungsten for everything on my Syncrowave.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:do you guys take any special precautions when grinding that 2% Thoriated?
Reply:Originally Posted by Tetra84do you guys take any special precautions when grinding that 2% Thoriated?
GMT+8, 2025-12-25 02:15 , Processed in 0.094084 second(s), 18 queries .
