Hex coupler
发表于 2021-8-31 23:45:21 | 显示全部楼层 |阅读模式
Does anyone know a steel supplier Can-US, where I can find hex shaft coupler female 1"ID, OD does not matter, call it piping or coupler material as long as it has a one inch hex inside diameter, tried all the local suppliers, everyone has hex shafting but cannot seem to find a supplier anywhere for the coupler material that goes over it or to connect two hex shafts?
Reply:Originally Posted by pistolnoonDoes anyone know a steel supplier Can-US, where I can find hex shaft coupler female 1"ID, OD does not matter, call it piping or coupler material as long as it has a one inch hex inside diameter, tried all the local suppliers, everyone has hex shafting but cannot seem to find a supplier anywhere for the coupler material that goes over it or to connect two hex shafts?
Reply:maby this is kinda what ur lookin for?http://www.mcmaster.com/#spacers-and-standoffs/=3ar40e-NateMiller Trailblazer 302gMiller Spoolmatic 30aLN-25 x 2Idealarc SP200Hypertherm Powermax 600
Reply:Originally Posted by \\NV.Welding//maby this is kinda what ur lookin for?http://www.mcmaster.com/#spacers-and-standoffs/=3ar40e
Reply:These are too big but maybe they can tell you where to get your 1" coupler.http://www.eskridgeinc.com/diggers/hexcouplers.htmlMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks, its sunday and checking Mcmaster.com but looks like it is small stuff, eskridgeinc.com looks promising will get back, 4-5 inches needed, would like about 1 foot, already thought of using a socket but do not want to sacrifice it, thinking this steel stock must be out there maybe have to check gear makers, as some gears have this id?Thought it would be more common.
Reply:I am surprised no one has told you to weld one up from flat stock-- fredLincoln 180C MIG
Reply:Try a good drive shaft shop alot of the PTO shafts for dump trucks etc used a hex shaft. Bill
Reply:I was going to suggest the the flat stock weld up route this morning, But thought no,everyone will think it a stupid idea,  but depending on the duty the shaft is required to do may be perfectly acceptable, Cheers  Gordon.Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:try a tractor supply place. case combines uses a hex coupler to connect the corn header drive to the combine on the 800 series headers.
Reply:Even generic tractor pto shafts are often 1" hex, any farm repair shop should be able to set you up.Also as previously mentioned ....   a driveline shop.  Occasionally one has to lengthen the slider, the internal hex is available, you just gotta know where to look.
Reply:I think that we're going to find out that 1" hex is a freak size.I believe the common pto shaft is 7/8" hex.Pistolnoon could be stuck buying an OEM piece.Good Luck
Reply:The part was discontinued from the mfg'd but I have found that they only discontiue parts that are commonly available, hecnce the search.Thanks for the suggestions.
Reply:Originally Posted by pistolnoonThe part was discontinued from the mfg'd but I have found that they only discontiue parts that are commonly available...
GMT+8, 2025-12-25 02:15 , Processed in 0.094766 second(s), 18 queries .
