just a little pulling hitch
发表于 2021-8-31 23:45:19 | 显示全部楼层 |阅读模式
machined out of a piece of 3"x3" solid bar stock. don't know what alloy. i DO know that the clevis is off a M88 rated 12 tons.
Reply:will you be towing tanks with that thing?
Reply:Originally Posted by bp626indamixwill you be towing tanks with that thing?
Reply:One thing is certain....his frame will let go before that thing does!StephenMillermatic 251Miller Syncrowave 200Miller 30A SpoolgunHypertherm Powermax 30Etc., etc., etc.............Cancer Sucks!
Reply:I like it. Nice and heavy duty!"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:What diameter is the clevis pin?City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by tanglediverWhat diameter is the clevis pin?
Reply:Very nice work! We had some 33 ton shackles at work, i swear they almost weighed what i weighYa gotta spend money to make money!
Reply:Nice monster hitch but you are still relying on that pin that holds it into the receiver.
Reply:the hitch will rip loose from the truck before any massive frame damage happens.   if his drivetrain is strong enough to actually stress parts.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:That pin will hold just fine, that's a very strong connection plus the pin probably wasn't machined out of "unknown alloy" but is probably a very shear resistant high grade alloy, just my .02
Reply:My brother pulled for years! The driveline will shatter befor that hitch! Great job.  Attached ImagesYou have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
Reply:i would have to Question the 5/8 pin holding the hitch in the receiver
Reply:Originally Posted by retiredIWi would have to Question the 5/8 pin holding the hitch in the receiver
Reply:thanks for the comments i asked about the 5/8 pin....i guess there is some kinda rule in his class that says it has to be there. the sled is safety chained to the truck to prevent a runaway.plus the truck is his daily driver so it had to be removable.
Reply:if the truck really is a pulling some beach you can elongate the 5/8" hitch pin hole in the stock receiver over time.    I have seen this on several trucks.  most of the time i recommend just reaming the hole to 3/4" and using a CAT grade 10 bolt through the hole.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Where in SE Ohio? I did some pullin! My truck is on the right:[ame]http://www.youtube.com/watch?v=4fltYuvdRxw&feature=player_embedded[/ame]
GMT+8, 2025-12-25 02:16 , Processed in 0.070117 second(s), 18 queries .
