查看: 2|回复: 0
Welding Cast Aluminum
发表于 2021-8-31 23:45:13 | 显示全部楼层 |阅读模式
Any thoughts on how to ID what alloy an aluminum casting is? I know there's certainly cast alloys that can be welded and some that don't weld well (my degree is in metallurgy) but am not sure how to id them in practice. I've looking at doing some fabrication work that would require welding on a cast AL automotive transfer case housing. (Borg Warner 13-45 case as used in 80's ford trucks)Thanks,    ~John
Reply:Blow a ton of money on an alloy analyzer or just weld it and see if it works...http://www.bruker-axs.com/xrf-aluminium-alloys.htmlWelding/Fab Pics: www.UtahWeld.com
Reply:Originally Posted by MikeGyverBlow a ton of money on an alloy analyzer or just weld it and see if it works...
Reply:Originally Posted by sdmulemanAny thoughts on how to ID what alloy an aluminum casting is? I know there's certainly cast alloys that can be welded and some that don't weld well (my degree is in metallurgy) but am not sure how to id them in practice. I've looking at doing some fabrication work that would require welding on a cast AL automotive transfer case housing. (Borg Warner 13-45 case as used in 80's ford trucks)Thanks,    ~John
Reply:Do what Dave stated..An make sure its clean..Good Luck
GMT+8, 2025-12-25 02:17 , Processed in 0.100692 second(s), 18 queries .
