steamfitters and pipefitters difference?
发表于 2021-8-31 23:45:10 | 显示全部楼层 |阅读模式
Whats the difference between the steamfitters and the pipefitters union, as far as the work is concerned? Which one would be best if i wanted to be a pipewelder out in the field? Thanks.Ranger 305gMillermatic 140 AutosetDewalt Chopsaw2 grindersMy Fists
Reply:Within the trade the difference is in how it is Labeled on the members book..... Since I've been for a long time, mine says BTJ (Building Trades Journeyman) "Steamfitter" most of the newer members will say "Pipefitter".....As far as any difference on the job... There is no difference. If a hand can meet the requirements of the Contractor, he works right along side the rest of the Journeymen. I've been on jobs as a "Orbital Welder" and had other guys with me that were  - Pipefitters / Steamfitters / Sprinkler Fitters / Plumber / Metal Trades / etc.If you want to be a pipe welder, you can contact any United Association Local. If you strictly want to be a pipeline welder, you will need to contact a local that has a "Pipeline Jurisdiction". Some locals are "combination" (plumbers, pipefitters, refrigeration and pipeline) and others are "straight line" locals with only pipefitters and welders.A lot depends where your located, where you want to work and where you want to live when your between jobs....... and if a local has enough work to take in new members.Thanks,HoboLincoln SA200's... at least 15 - 20. They come and go. Growing partial to the "Short Hoods" in my old age. Last count on Short Hoods was 13 in possession.
Reply:Steamfitter and pipe fitter are the same job at my plant. Same guy. Welders weld.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Depends on the city and local union bull$hit in the contracts.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Im located in southern california. 20 miles east of downtown los angeles. What locals would be near me?Ranger 305gMillermatic 140 AutosetDewalt Chopsaw2 grindersMy Fists
Reply:Steamfitters start drinking much earlier in the day.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Originally Posted by bp626indamixIm located in southern california. 20 miles east of downtown los angeles. What locals would be near me?
Reply:Thanks for the good info, hobohilton. Local 250 would probably work out better for me.Ranger 305gMillermatic 140 AutosetDewalt Chopsaw2 grindersMy Fists
GMT+8, 2025-12-25 02:16 , Processed in 0.098548 second(s), 18 queries .
