You might be a redneck if......
发表于 2021-8-31 23:44:59 | 显示全部楼层 |阅读模式
...... if you have a BBQ pit mounted to your welding table..... Wish I had a true work shop, but instead I've got to settle for working underneath my 2 car carport. Last weekend, I built my new welding table. I did not have room for it, my BBQ pit, 2 pickups and other odds and ends to all fit underneath the carport. So, I tore my charcoal BBQ pit down and welded an angle iron frame for it to mount on, welded 1/2 round rod to the angle iron, then 2 pieces of square tubing welded underneath the new table to allow the BBQ grill to slide in to the tubing to cook and then can be removed for when it's time to work on the table.I'm loving playing with my welder and all the neat ideas I've got swimming through my brain.....
Reply:Tell people it's a heat treat oven when they ask... of course if it smells like bbq cooking that might not get rid of them
Reply:Excellent use of available space, it's good to see that American ingenuity is alive and well...MillerMatic 135Handler 210 w/ DP3035 SpoolgunLincoln AC-225Primeweld TIG225xEverlast Power Arc 200Weldcraft TIG rigSmith American Classic O/AEvolution Rage 2 SawTD Cutmaster 52Miller Thunderbolt with HF Box
Reply:Nice solve! Your gonna get hungry though being that close to it!! If your table stays that clean you can put some elements under it and use it for a flat top grill!!!! Mmmmm....pancakes!200amp Air Liquide MIG, Hypertherm Plasma, Harris torches, Optrel helmet, Makita angle grinders, Pre-China Delta chop saw and belt sander, Miller leathers, shop made jigs etc, North- welders backpack.
Reply:if ihad the luxury of a carport i sure wouldnt waste it on cars...
Reply:Redneck rod oven.
Reply:That's a neat solution!  I like it.  Way to go!A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter   Victor O/A
Reply:nice fab table, I like the way you work under pressure.  hkstwn7
GMT+8, 2025-12-25 04:03 , Processed in 0.133842 second(s), 18 queries .
