thoughts on my project idea
发表于 2021-8-31 23:44:58 | 显示全部楼层 |阅读模式
Hey guys built this table awhile ago and ive got extra material to build more took a pic put it on c list and see what happens. What do you think either (pos) or (neg) i can take it. But you can use this thing for camping grillin cleaning fish and game,Its got soooo many uses  lets hear it Attached Imagesmiller maxstar 150   hobart handler 210 w mig conversion hobart 250 arc force plasma cutter    boston ind cutting torch miller performance auto darkening helmet milwalkee 14in chop saw 10,000 watt generator huge drill press and industrial band saw
Reply:If you make and sell something to fit into a hitch receptacle whether it's designed to be used while the vehicle is in motion or not, I'd suggest you find a good insurance carrier and be sure they'll cover this type of work.  Most won't.I'm not saying you're a bad craftsman, I'm saying in today's world you have to consider the legal issues.
Reply:tbone550  may be right and aint it a shame...nice functional table, good idea...
Reply:Hey, I like it. You might find a way to take advantage of your unmitered corners by using the open ends as a receiver for some sort of removable attachments. I don't really have anything in mind, but that's just something that could be explored.
Reply:Now I'm picturing an arm that swings out that holds a platform for a little grill, leaving the table open for other things. Something like that could make a nice tailgater picnic table for people without a truck.I might try to build something like that myself. This is going to be big. Good thing we're in different states!
Reply:Cons- doesn't look like you can open the door on the Van.Pros- yes handy to have onePlenty like it out there so it is not a bad ideahttp://www.nationaltailgate.com/stor...-13-p-819.htmlhttp://www.etrailer.com/Hitch-Access....html?feed=npnEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:With the arm so far away from the hitch and that much weight on the end the road bumps will put alot of stress on it. Put your brace as close to the hitch as possible. Let them install it and post weight capacity on it. No different than building a trailer and selling it. The easy part is building it. I have found that the marketing is the tough part. Wife says all the time "you should sell that" i say you sell it i will build it. Give it a shot.Annamel TW9Y Georgia
Reply:I'd say make it at least fold flat or quick release for the table/arm connection... otherwise what are you supposed to do with it when your not using it? you need a way to store it I'd say...miller 330a bp TIGmiller dynasty 200DX TIGmillermatic 185 MIGthermal dynamics cutmaster 101 plasma cuttersnap-on YA5550 plasma cutterhypertherm powermax 30 plasma cutterbaileigh CS225 cold sawetc....
Reply:the top comes off and has a chunk of pipe youcan adj it by drillin holes in it and suppose i should put on reciept that its for stationary use and you can open door  i am about 230pounds and i stood on the peice that comes outa reciever and didnt bend or breakmiller maxstar 150   hobart handler 210 w mig conversion hobart 250 arc force plasma cutter    boston ind cutting torch miller performance auto darkening helmet milwalkee 14in chop saw 10,000 watt generator huge drill press and industrial band saw
GMT+8, 2025-12-25 04:14 , Processed in 0.095526 second(s), 18 queries .
