Ideas for money making projects using drop off + raw material
发表于 2021-8-31 23:44:58 | 显示全部楼层 |阅读模式
Hey guys, it appears my hours are steadily dropping and i am looking for ways to make some additional cash. I have access to a large fabrication shop and all the drop off material i want. (mostly plate steel, 3/16,1/4,5/16) also have raw material available such as angle,tubing,flat bar,square bar,channel, etc I started working with inventor and am teaching my self the program now. looks like i can easily design parts to be cut in the plasma right away. Looking for ideas of small projects that i can make some money on. Any ideas are appreciated.Thanks
Reply:I thought you were going to give US ideas.You first.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Originally Posted by shovelonI thought you were going to give US ideas.You first.
Reply:Baseball bat-proof mailboxes?A half-round of 6"sch 80 pipe for the top, 3/8" plate for the sides, bottom, and back, 1/4" plate for the door, and some 1/2" round bar for the hinge pin and door handle... I made one for my uncle after all the mailboxes on his road were smashed 4 times in 3 weeks. A week later, there were the splintered remains of a wood baseball bat on the ground at the end of the driveway.  I have requests for a half dozen more, although I sort of doubt they'll need them, as I figure those kids probably learned their lesson.  It could NOT have felt pleasant to be holding the other end of that bat when it met a solid plate of steel at 40+ mphLast edited by anickode; 08-14-2012 at 03:43 PM.You didn't build that.'85 Miller AEAD-200LE
Reply:Originally Posted by anickodeBaseball bat-proof mailboxes?A half-round of 6"sch 80 pipe for the top, 3/8" plate for the sides, bottom, and back, 1/4" plate for the door, and some 1/2" round bar for the hinge pin and door handle... I made one for my uncle after all the mailboxes on his road were smashed 4 times in 3 weeks. A week later, there were the splintered remains of a wood baseball bat on the ground at the end of the driveway.  I have requests for a half dozen more, although I sort of doubt they'll need them, as I figure those kids probably learned their lesson.  It could NOT have felt pleasant to be holding the other end of that bat when it met a solid plate of steel at 40+ mph
Reply:A small numbered stand to hold spark-plugs in order.
Reply:fire rings are easy to do in plate if you've got the equipment to cut and bend it. and easy to make decrative if you've got access to a cutting table.signs, name plates, BBQ brands, decrative lettering, wine racks, coat racks, ..... the list goes on and on.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Yard art always seems to sell.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Metal cages for commercial/residential air conditioning units to prevent copper theft.TxDoc's Photos Lincoln SP175 PlusLincoln Power Mig 256Lincoln 250 LX Spool Gun Lincoln Precision Tig 225 Hypertherm 600 KMG 2x72 Belt GrinderBaldor 812RE Grinder
Reply:Here's my first design for a mailbox built out of 1/4" plate. Attached Images
Reply:Put a peaked roof and a little chimney on that mailbox.My neighboor has one and I would bet his wife made him by it as it is "decorative"Still has a square door on front held shut by a little magnet.
Reply:Depending on the steel you have steel targets/target stands would be a seller.
Reply:Paper weights.
Reply:Did not have access to the brake so i made do with the shear. Did the peaked roof instead, i think it looks a lot nicer this way. Weighs in at 70lbs
Reply:A 1/4 plate mailbox....Awesome. That thing will be indestructible versus all but an suv ramming it...and even then you'll find it launched a few feet away, probably fine.  I did something similar for a buddy who's neighborhood was always having it's boxes trashed. Some fools kept smashing them, so we made a box from 1/8th plate, and stuck it on top of steel pipe. 2 weeks later, smashed box, smashed box, smashed box, then bat splinters LOL.As for yard art, that same buddy and I made a few "prototype" hanging plant stands for his mother. Got the idea from the welding projects section. Ended up making about 50 more for the local farmers market HTP Invertig 221-DV -- get's dragged everywhere.Syncro 200 -- "The Boat Anchor" at the lab.Lincoln 125 MIG
Reply:Whoever swings a bat at that will have a broken side rear glass for sure. Happened to my friend whe. We were young. I laughed so hard for days, he got what he deserved. Great job!I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by ThorsHammerfire rings are easy to do in plate if you've got the equipment to cut and bend it. and easy to make decrative if you've got access to a cutting table.signs, name plates, BBQ brands, decrative lettering, wine racks, coat racks, ..... the list goes on and on.
Reply:Hi, one reason why solid brick square letter boxes are popular in OZ, totally indestructable and rust proof.....mine's 25 years old.I'd try garden stuff to make simple cheap plant hangers and stands.One design on my one day to do list is a plant pot riser stand.....15mm tube (600mm long) and a ring welded at the top.....the whole lot green powdercoated or baked enamel....you put the plant pot into the ring and push the tube into the soil in a garden bed....the plant in the pot is kept just above the garden bed and keeps it from being overshadowed by the bigger bedded plants.....cost $1 to make....sells for $5....500% profit. Ian.
Reply:Just a word of advice, I've heard that USPS-approved mailboxes and mail posts are designed to "break away" if a car or snowplow hits it, and that if you "overbuild" your mailbox or the post it sits on, and somebody has a car accident and your 70# mailbox takes their head off, you can be held liable.I am not a lawyer, and I don't know if this is true, but it is something that I heard...
Reply:How about custom steps that fit in a trailer hitch receiver, or bolt on?  Some seem a little pricy.  There are some that bolt on to an existing receiver or drawbar.  And then there are those protector plates that keep you from ramming the trailer tongue into the back of the vehicle.If you live in a muddy or snowy area, shoe/boot scrapers.  Some are rather artistic.    My son made some $ making a couple sets of heavy-duty fireplace tools using some twisted/hammered stock we got from King Architectural Metals.Think of things you might be able to sell through (or to) a locally owned truck/car accessory place, trailer sales, nursery/garden center, fireplace store and the like.  Having the ability to CNC plasma cut opens a lot of possibilities."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by KelvinJust a word of advice, I've heard that USPS-approved mailboxes and mail posts are designed to "break away" if a car or snowplow hits it, and that if you "overbuild" your mailbox or the post it sits on, and somebody has a car accident and your 70# mailbox takes their head off, you can be held liable.I am not a lawyer, and I don't know if this is true, but it is something that I heard...
Reply:Re-the guy with the head missing in the letter box......he won't need a lawyer to press his claim.When you have to consider all the variables, don't forget to allow for meteorite strikes too, and maybe a piece of the last NASA space shot that was late in arriving....LOL.Come to think of it, with the meteorite possibility a real threat, how about an umbreller made from a garbage tin cover and a piece of pipe for a handle......bullet proof.Ian.
Reply:Has anybody ever considered lying in wait for the bat swingers?Ian.
Reply:Welcome signs, no soliciting signs, pro gun signs,  Small shelf brackets, house numbers, name signs, small step stools, wine racks, fireplace guards, overhead pot holders, overhead wineglass holders, napkin holders, the list can go on and on.Offering CNC Plasma cutting and welding projects.Follow me on facebook https://www.facebook.com/nobigdeal.fabSupport those that support WW.A little OT but I worked with a guy back in the 70's and when he was a kid in the country he tought it "fun" to hit mailboxes. Welded a piece of channel to his POS truck to extend the bumper out the right side. Drove around (at night of course) snapping the posts off.Well, one of the farmers had enough of that. He stuck an old differential in the ground for a post.So the kid drives by one night, hits the post, does an immediate 360 in the middle of the road, bends the channel around to where the passenger door won't open.That ended his "career" as  "mail box tester".
Reply:Originally Posted by millratA little OT but I worked with a guy back in the 70's and when he was a kid in the country he tought it "fun" to hit mailboxes. Welded a piece of channel to his POS truck to extend the bumper out the right side. Drove around (at night of course) snapping the posts off.Well, one of the farmers had enough of that. He stuck an old differential in the ground for a post.So the kid drives by one night, hits the post, does an immediate 360 in the middle of the road, bends the channel around to where the passenger door won't open.That ended his "career" as  "mail box tester".
GMT+8, 2025-12-25 04:12 , Processed in 0.086597 second(s), 18 queries .
