Stress relieving???
发表于 2021-8-31 23:44:57 | 显示全部楼层 |阅读模式
I have a part I'm building they is a piece of 1x2x14g steel tube that is 55" long and has a gradual cure about 3-4" deep across it. It is curved the easy way not the hard way. I have the piece in a jig currently holding the curve. What would be the best way to "stress relieve" it? So that when I take it out of the jig is holds the curve. I know going and actually having it stress relieved would work, but that is not an option.
Reply:I would over-bend the tube a slight amount, and see if the curve is correct after it "springs"back to a relaxed position. Do this over-bend process in small increments, until you attain the correct shape.Bgbkwndo.
Reply:I wont be able to over bend it. It's not a consistent radius and the jig would not allow me to over bend it any how.
Reply:Here is an old thread http://weldingweb.com/vbb/showthread.php?t=47275
Reply:I'd post heat it. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Listen to this guy ^^^^ thats exactly how you should do it. I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
GMT+8, 2025-12-25 04:05 , Processed in 0.092643 second(s), 18 queries .
