Help choosing filler size
发表于 2021-8-31 23:44:53 | 显示全部楼层 |阅读模式
Hey guys!I'll be welding (GTAW) together aluminium in a full-open corner joint. The aluminium thickness is 2mm or 0.078in.Could you give me some advice on what size filler rod I should use for this weld?Best regardsErik
Reply:I would try 1/16" 4043.  If that burns off too fast, then jump up to 3/32"MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by DesertRider33I would try 1/16" 4043.  If that burns off too fast, then jump up to 3/32"
Reply:Usually filler size is a matter of preference rather than necessity.  A competent welder can use many different sizes of filler to accomplish the same task but they usually prefer one or the other.1/16 is probably what I would use on an open corner joint.  Just make sure to dab it in/out quick or it will ball up and just cause problems.Have we all gone mad?
Reply:start small work bigger, i know that is kind of vauge but i have always had options in filler size. start with the 1/16 like others have suggested
Reply:Thanks for all the help!Then I'll get som 1/16" filler. My expreience when Tig welding (newbie) is that I find it's easier using a smaller size filler and adding more frequently but that's just me
GMT+8, 2025-12-25 04:12 , Processed in 0.092180 second(s), 18 queries .
