Stick rod suggestions
发表于 2021-8-31 23:44:50 | 显示全部楼层 |阅读模式
I'm putting together a bicycle trailer using old steel bicycle frames. The frames I have vary in steel composition... one is 4130 tubing, the rest are unknown. One of the unknown's is very thin tubing and I believe it's higher grade steel than the 4130. The others seem more clunky/heavier than the 4130 so I believe they are lower-grade steel than the 4130.I'd like to take bits and pieces from these frames as needed, so basically the project may have mixed tubing.Is there a general stick rod I can use that will work fine welding these different tubes together?I'm aware of stick not being recommended for thin material, but I don't really care =). I have a Lincoln Electric AC 225 arc welder, which goes down to 40 amps (@ 25v).
Reply:Wow, you're biting off alot expecting to stick weld the thin tube, especially with an AC buzz box.   Try some 1/16" 6011 or 6013.Do you know how to run a 6011?  If not, use the 6013...MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:You would be alot better off with an oxy/ act torch. My preference. Harold
Reply:Originally Posted by WelderskelterYou would be alot better off with an oxy/ act torch. My preference. Harold
Reply:4130 is chrome molly. Light and strong stuff. 7018 electrode is always recommended for welding 4130.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I'd rather have to buy new mild steel tubing rather than trying to make a trailer out of used bike frames. Even if someone gave me a 1000 lbs of old bikes.Tough as nails and damn near as smart
GMT+8, 2025-12-25 04:13 , Processed in 0.128198 second(s), 18 queries .
