to aluminum mig or tig
发表于 2021-8-31 23:44:49 | 显示全部楼层 |阅读模式
Okay. I need water tight welds. Should I go with mig with a spool gun or a tig?
Reply:Originally Posted by pyroracing85Okay. I need water tight welds. Should I go with mig with a spool gun or a tig?
Reply:As stated more details would be nice. A lot would depend on how much you are going to be doing as well.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:You should go with a competent weldor first. Having that as mentioned, it all depends on material and application. The absolute best for weld density and lack of porosity is O/F welding, but since its not mentioned in your first post, I will assume thats not one of your capabilitys. Details please.
GMT+8, 2025-12-25 04:13 , Processed in 0.096376 second(s), 18 queries .
