Meat saw
发表于 2021-8-31 23:44:43 | 显示全部楼层 |阅读模式
I don't do walk ins.. but friends show up from time to time and mess up the work order. This one is not so bad, a meat saw arbor with a bad bearing dia, and the game from meat hunters is stacking up. A lttle TRADING IS GOING to HAPPEN!Material is non-magnetic SS, so I went with 308L, tigged the first pass with 1/16" at 75amps and cover passed with twisted 3/64" at 60amps or so, then dropped in coolant.Machined the 25mm dia. to .985" (that's +.0006") and stoned to .+.0002".There could be a change in the X-mas menu coming up! Matt Attached Images
Reply:That's worth a pack of sausage at least right?  Lincoln AC225 and CartLincoln WeldPak HD and CartOne hand
Reply:Maybe at least a roast or something!!!  BTW...nice job!
Reply:Looks good. I'm curious why you used twisted wire filler for the cover pass?BTW, what game? anything exotic (I mean non-venison)?JasonXMT 350 MPA Dynasty 280DXSuitcase 8RC / OptimaSpoolmatic 30AThermco Ar / C02 mixerAssorted O/A gear
Reply:very cool man
Reply:Originally Posted by MonicaThat's worth a pack of sausage at least right?
Reply:Just found this thread. Looks like a good job there.   Had one packing plant job in this morning with another large one been in the works for a couple of weeks now (I'll probably post some pics of that once I get the stuff in needed to do it). Of course it could be because my dad owns the local packing plant. :-)Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
GMT+8, 2025-12-25 04:13 , Processed in 0.091230 second(s), 18 queries .
