solid wire
发表于 2021-8-31 23:44:38 | 显示全部楼层 |阅读模式
Hi everybody:Question to all.!the 120 welders seem like they don't melt the wire as good as 220 machine.Question:is there a softer melting wire for thin metal wok with 120 welder.
Reply:what diameter is the wire you're using? what thickness is the metal you're working with? what settings on the machine.lower setting on the machine is going to melt metal slower. but there could be more involved than just that.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Using a MillerMatic 130 on 30 amp dedicated circuit.wire--.023Voltage --no.2 setting45  wire speed16 guage material .There are. thank you for taking the timelakehunter
GMT+8, 2025-12-25 05:54 , Processed in 0.102202 second(s), 18 queries .
