Can you use plain steel .035 mig wire for 0xy-fuel welding?
发表于 2021-8-31 23:44:34 | 显示全部楼层 |阅读模式
Any reason why this won't work?  My understanding is that the flame keeps the oxygen away, and it would seem that .035 wire would work well on thin sheet with a 00 or 000 welding tip.Thanks!Mark D.
Reply:sure it will work if you can weld. not my first choice of process for something very thin but have at it!
Reply:I know it will be a challenge, but this is a hobby for me and I have a nice torch setup and old ac/dc idealarc.  I'd like to learn to use what I have to the best of my ability, and learning to oxy-fuel weld should make tig that much easier to learn if I have go down that road.I was pretty sure the mig wire would work, but I wanted to bounce it off the pros before I actually started fooling around with it.Thanks!Mark D.
Reply:Can be used for tig welding too.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:I would avoid it for learning. Part of the requirement for the filler metal in OA welding of thin material is to act as a heat-sink. I use 1/16" filler on materials down to about .015" thick base metal. The other problem is the alloy. ER series fillers have additional de-oxidixers etc that just spark and sizzle, and sparks can lead to torch "pops". Pick up a pound of RG-45 1/16" and you will be fine. OA is perfect for thin materials, at least down to about .010" for the average weldor.
GMT+8, 2025-12-25 04:03 , Processed in 0.093987 second(s), 18 queries .
