Shoe Handle Wire Brush
发表于 2021-8-31 23:44:33 | 显示全部楼层 |阅读模式
I was taught something by an old boilermaker years ago, about a use for shoe handle wire brushes. Does anyone know of a use in welding? Other than just brushing? Just Curious??? if they still teach this....
Reply:Are we playing 20 Questins today?Second post that didn't make much sense at all.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:What a waste of good equipment.Syncro 250 DXDynasty 200 DXMM 251 w/30A SGHH187Dialarc 250 AC/DCHypertherm PM 600 & PM 1250Smith, Harris, Victor O/AMore grinders than handsSmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.Reply With Quote6"XX P5P8 6G
Reply:wtf is a shoe handle wire brush?
Reply:Originally Posted by weldbeadwtf is a shoe handle wire brush?
Reply:they are aerodynamic and are good to throw at a woodchuck when you see one in the yard...?
Reply:Good Try!  Ok here goes...When laying out a "bull nose", also called a pipe cap.  Use the shoe handled wire brush curvature to mark the line from the base line cut, to the center cut that is marked on the end of the pipe.The end of the brush, is placed on the end of the pipe (the center cut) to mark out the curved line to the base line.  After the pipe is cut, the ears are heated and bent to form a pipe cap. This procedure makes a fine looking pipe cap. Hope this helps  Ps. This procedure works for some reducers also.6"XX P5P8 6G
Reply:Originally Posted by CofeWhen laying out a "bull nose", also called a pipe cap.  Use the shoe handled wire brush curvature to mark the line from the base line cut, to the center cut that is marked on the end of the pipe.The end of the brush, is placed on the end of the pipe (the center cut) to mark out the curved line to the base line.  After the pipe is cut, the ears are heated and bent to form a pipe cap. This procedure makes a fine looking pipe cap. Hope this helps  Ps. This procedure works for some reducers also.
Reply:Cofe, I'm lost too.Sounds like it'd be leaving the complex lay-out for the cut of an unknown size expensive pipe, up to the random shape of a 99 cent brush handle.Good Luck Originally Posted by weldbeadthey are aerodynamic and are good to throw at a woodchuck when you see one in the yard...?
Reply:Here is a layout by pipe fitters handbook. Attached Images6"XX P5P8 6G
Reply:Originally Posted by weldbeadthey are aerodynamic and are good to throw at a woodchuck when you see one in the yard...?
Reply:Thanks for the illustration Cofe.  Believe it or not, you just gave me an idea.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:And here I thought the answer was, it makes for a darn good back scratcher! #1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Originally Posted by Ken DennisAnd here I thought the answer was, it makes for a darn good back scratcher!
Reply:Originally Posted by CofeHere is a layout by pipe fitters handbook.
GMT+8, 2025-12-25 04:13 , Processed in 0.097248 second(s), 18 queries .
