Out Door table
发表于 2021-8-31 23:44:32 | 显示全部楼层 |阅读模式
This one really worked, looked better in the flesh than in the pics.25.4mm, 304, 3mm wall SHS. (1" with 1/8 wall) Radius edge.Powder Coated "Jasper" with chromate conversion pre treatment.Used 304 as I don't like the finish of gal and the section size and the weld size in Aluminium was a bit big. Would use 316 if not powder coated, 3mm used as it saves time tack blending together then welding up with little distortion.Adjustable swivel feet , 10mm toughened glass , 2400x1200(3/8 Tempered glass , 8'x4' )Brett Attached ImagesA good guess is better than a bad measurement
Reply:That's a sweet table. I like the angles.
Reply:nice work
Reply:you should have used 3/8" plate that glass aint gonna last at all...
Reply:Nice table. Clean design. Now your going to need about a dozen new chairs.
Reply:And a huge bottle of glass cleaner.Great table Brett, I hope to make something not quite so big this winter.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Looks nice, now all ya gotta do is lose the chairs  (splinters in yer bum)"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Nice table. Very clean looking.
Reply:Really liked the design. Think ill steal the idea and make a smaller one..
Reply:Very nice touch with the leg design. The finish looks great.Gordhttp://gordsgarage.wordpress.com/
Reply:Originally Posted by farmersammLooks nice, now all ya gotta do is lose the chairs  (splinters in yer bum)
Reply:Originally Posted by gordsgarageVery nice touch with the leg design. The finish looks great.Gord
Reply:Nice design with a clean look to it and I like the idea of a stainless table outside, good job.I am what I am, Deal with it!If necessity is the Mother of Invention, I must be the Father of Desperation!
Reply:Originally Posted by alutigReally liked the design. Think ill steal the idea and make a smaller one..
Reply:Nice Work I like it.
GMT+8, 2025-12-25 04:12 , Processed in 0.120868 second(s), 18 queries .
