drilling hole in a railroad spike.
发表于 2021-8-31 23:44:22 | 显示全部楼层 |阅读模式
wasnt sure where to post this. i have these spikes bent like hooks and need to drill a mounting hole in each one to mount them to a piece of wood. any suggestions? thanks Attached ImagesZach WareOwnerMid-GA Outdoor & Equipment ServiceByron GA478-960-2014
Reply:I'd heat them up and punch and drift the holes myself.[ame]http://www.youtube.com/watch?v=tuVVkIZxh2w[/ame]Since they are a spike anyways, you could simply forge a point and drive them into the wood also. You couldn't find any better spikes?.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:that video is cool. dad found these some years back and ive been hanging on to them for quite a while. can they be heated with O/A and have a nail with the head cut off drove thru them?Zach WareOwnerMid-GA Outdoor & Equipment ServiceByron GA478-960-2014
Reply:It sounds like you are wanting to mount the spike end on a plank and use the head for a coat rack. If so that is a cool Idea As for drilling, a drill press, slow speed and cutting oil should work. A neat trick on the nails or screws you mount them with: Add a blob of metal to the head after you drive it home (mig,tig,stick, dont matter) and before it cools, whack it on four sides with a hammer. Tada, instant "hand forged" nail. If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:Originally Posted by midGAoutdoorthat video is cool. dad found these some years back and ive been hanging on to them for quite a while. can they be heated with O/A and have a nail with the head cut off drove thru them?
Reply:midGAoutdoorRegardless of how you make the hole.  Your spikes warrants a square bolt head.Opus
Reply:aren't nails usually way too soft to be used for this type of thing?
Reply:I would use a drillpress, myself.  Just go slow and use coolant.
GMT+8, 2025-12-25 04:13 , Processed in 0.066196 second(s), 18 queries .
