Handrail problem
发表于 2021-8-31 23:44:15 | 显示全部楼层 |阅读模式
This was built out of order ....our tile guy had trouble with his marble order(for the treads and riser's)The welder went ahead and did his thing,I followed and installed the wood much like this stair caseMany of the supporting arms had to be moved,etc...Ok so this weekend the tile guy is installing the marble and now we find out that the landing is off quite a bit and has to be padded up...it also changes just about everything else.Should be a interesting day Monday I will post pics and let you know just how much I'm f***ked.
Reply:Originally Posted by IamVinceThis was built out of order ....our tile guy had trouble with his marble order(for the treads and riser's)The welder went ahead and did his thing,I followed and installed the wood much like this stair caseMany of the supporting arms had to be moved,etc...Ok so this weekend the tile guy is installing the marble and now we find out that the landing is off quite a bit and has to be padded up...it also changes just about everything else.Should be a interesting day Monday I will post pics and let you know just how much I'm f***ked.
Reply:Thank you...here's a pic as we were building it...notice the welder on the landing,supporting arms are never where they are supose to be luckily I can weld a little so moving them to the correct height is not a big deal.The other handrail will be a little more involved I bet
Reply:Originally Posted by IamVinceShould be a interesting day Monday I will post pics and let you know just how much I'm f***ked.
Reply:I feel sorry for the owners, really, can't imagine living in a dump like that WTF! hope they get help or a job soon!HH187Hobart 500i plasma cutterClark 4.5" GrinderDewalt 14" chop saw30 gallom 1.6 hp compressor10 gallon pressure pot sand blasterlots of hand tools
Reply:I do not know what happened to our tile guy but I really need the landing finished before I can go much farther.Today I cut off and raised the landing part of the handrail.Also where the angle meets the landing(no pic)was re-done. I had just been given the ac lift...came in real handy today.Look at how much thin-set is under the treads...starts out about right at the top but by the time it gets to the landing its a good 1 1/2"Also notice where the handrail had been screwed to the wall?Waiting for the landing tom be installed before I bring it back down...its just floating now.
Reply:awesome worki take it that baby welder is easy to carry around on jobs like that huh?
Reply:Originally Posted by Nickosawesome worki take it that baby welder is easy to carry around on jobs like that huh?
Reply:We use a little porta'tig set-up with small bottles, weighs 35-40 lbs and we just hook it up to the leads on the truck, it's pretty bad ***...."...My pappy was a pistol I'm a son of a gun...""...God is great, beer is good, and people are crazy..."
Reply:Pic that I forgot the other dayWell it's finished with only a few flaws...but I'd about have to point them out(my boss will spot them quick)
GMT+8, 2025-12-25 04:12 , Processed in 0.107473 second(s), 18 queries .
