Boat trailer gooseneck conversion and break table
发表于 2021-8-31 23:44:14 | 显示全部楼层 |阅读模式
Two very different items, but a couple of things from last week I thought were worth sharing.   The trailer was not a paying job, it was for a friend.  He lives in a typical suburban area with a tight driveway and narrow road.  Getting the trailer in and out is a huge chore and involves cutting through ditches.  He came up with the idea of converting it and off we went.  The original frame is composed of 6"x3"x3/16" HSS.  All new material is 6"x3"x1/4" and gusset tubes are 6"x2"x1/4" HSS or 2.5x2.5x 3/16" HSS blocking.  All critical welds are uphill (which are the majority).  Overall it shortened his actual road length by around 30", and gives much better control.  He is going to put on the jack, bumper stands, and bumpers.  I am structure only.  This past Friday we didnt have alot going on and I have been cleaning out and organizing the back office so the guys could have some sort of a breakroom and area to relax.  One of them and I brainstormed a bit on something to build for a table.  We came up with a rough idea and I set them loose with whatever we had for clean drop material in the shop.  3 hours later was this.  I did my typical spangle type finish and put 3 coats of polyurethane on it.  Top is 4' x 4' and I am picking up the glass tomorrow.  Its a bit on the big side, but its another place we can layout plans.  Last edited by brandon75173; 12-19-2010 at 05:57 PM.Lots of toys.
Reply:that is probably the nicest break room table i have ever seen. great work
Reply:personally i never liked the idea of tube on boat trailers, but that looks plenty strong.    How are you going to affix the landing gear?Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:I've seen both tube and non-tube framed boat trailers, but I ain't never seen one this large...credit to http://www.browardtrailer.net/BoatTrailerMainPage.html Attached ImagesCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by Dualiepersonally i never liked the idea of tube on boat trailers, but that looks plenty strong.    How are you going to affix the landing gear?
Reply:Originally Posted by larpheadthat is probably the nicest break room table i have ever seen. great work
Reply:by landing gear i mean the jack that you use to unhook it from the tow vehicleVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Holy Sh**, that's an impressive table!!! The boat stuff is nice also. Good to let your crew loose every now and then.
Reply:Originally Posted by Dualieby landing gear i mean the jack that you use to unhook it from the tow vehicle
Reply:Im not a boat guy eather but I am a truck driver and I wonder what they are useing to pull that trailer? And really wouldnt it be better in the water than going down the road? I like the table for sure. Reading this site has given me lots of ideas!
GMT+8, 2025-12-25 07:28 , Processed in 0.066489 second(s), 18 queries .
