Anyone with a speedglas 9100xx hood?
发表于 2021-8-31 23:44:05 | 显示全部楼层 |阅读模式
When welding in a booth with white walls, is it okay to have the side shields without the black non see through insert in them? Is the shade dark enough for the sides? Arc welding btw.
Reply:I say this because I thought the side are meant for open areas, not enclosed for the flash to bounce around the walls and reflect in the sides.
Reply:I can't answer you for sure but, they are still shade 5. I also don't weld in a white booth so I'm not sure.
Reply:They would give UV protection which is what give you the sore eyes.
Reply:Originally Posted by LarryOThey would give UV protection which is what give you the sore eyes.
Reply:Originally Posted by tryingtoweld?????
Reply:Originally Posted by LarryOWhats not to understand?UV is what gives you welder flash.Side panels in Speedglas helmet would have UV protection + shade 5.To the OP, its probably a matter of personal preferance, if it anoys you to have a flash coming from the sides.
Reply:My shop is completely white. I weld with the side windows not blocked. I weld all day long. Never had any issues.
Reply:I would contact Speedglas on this one. I have a SG. 9100XX without sideview lenses. The way I understand it is that they are to prevent flash from other welders but yet allow you to see better in the shop when walking,ect..Speedglass 1-800-243-4630
Reply:Is it really that difficult to put the hood up before walking around the shopTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
GMT+8, 2025-12-25 04:02 , Processed in 0.066743 second(s), 18 queries .
