Fcaw ?
发表于 2021-8-31 23:44:04 | 显示全部楼层 |阅读模式
I'm running .035 Lincoln Inner shield in my machine. My question is, what stick is this wire equal to, 6010, 7018 or ???ThanksTom
Reply:Its been stated before that flux-core is similar to 7018, equal i cant say.Did you know lincoln makes over a dozen diffrent flavors of innershield,www.lincolnelectric.co Briggs weldnpower 225/210/cvLn-25 suitcaseMillermatic 130
Reply:Sorry, forgot to put that! NR211 is what I'm running.
Reply:It's not really 'equal' to any stick rod. It's a 70kpsi tensile filler if that's what you asking.Welding/Fab Pics: www.UtahWeld.com
Reply:Originally Posted by MikeGyverIt's not really 'equal' to any stick rod. It's a 70kpsi tensile filler if that's what you asking.
Reply:nr211 is equal to e 7018-1Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:Originally Posted by tom-in-newallaThat's what I was looking for, thanks! Since we're on this, which has a higher tensile strength, FCAW or Mig?
GMT+8, 2025-12-25 04:02 , Processed in 0.071004 second(s), 18 queries .
