Century 117-002 schematic
发表于 2021-8-31 23:44:02 | 显示全部楼层 |阅读模式
I am trying to locate a schematic for a All Star (Snap-On) MIG model 117-002.  I have a problem with it in that the Weld Transformer  (?) turns ON when the Main Power Switch is turned ON.  The Wire Feed Stepper Motor operates normally.  I.E. it only feeds wire when the trigger switch is activated.  Any help out there?
Reply:If you send me your email address I will send the manualCheers
Reply:Email address on the way
Reply:Have just emailed it to you
GMT+8, 2025-12-25 05:47 , Processed in 0.104470 second(s), 18 queries .
