Simple project
发表于 2021-8-31 23:43:59 | 显示全部楼层 |阅读模式
This is a very simple project and is a big help in welding smaller projects. My dad called it a welders finger, it is a device made to hold small objects while tacking in place. I bought the steel at the scrap yard to make this, it was 3.56 total in price. It frees up a hand so you can hold the gun (mig welder) with both hands to get a straight shot at the place to be welded. its very handy when welding small objects. Attached ImagesLast edited by wrenchit; 09-25-2005 at 12:59 AM.Reason: wrong picture
Reply:Neat Idea.
Reply:I like it
Reply:looks good but i'd probably get frustrated with it
Reply:i would probably get frustrated w/ that too guy
Reply:Not as frustrating as working with one hand, my left hand is crippled.
Reply:A good third hand for tig welding is just what I needed, good idea.
Reply:That is neat.  I'm going to have to make a few of those.-Heath
Reply:One of the welding books shows how to make something similar but out of 1/4" or 3/8" bar stock, one piece bent into a V for the end, the other a long piece sharpened and bent over at the end. No extra weight added.
Reply:I've seen this on the other welding forums as well.Don't use it to ground, it will arc between the tip and the work. Student on a mission.   Be the best. If I can't be the best I sure as hell won't be the worst.
Reply:Welding with only one hand would be a challenge for sure. Somedays I need three hands.
Reply:I made up a couple of similar ones out of cold roll steel.  They have been real handy for intricate TIG work.  (Great for when you need one hand to hold the torch, and the other one to hold the filler rod, and need your parts to stay put for tack welding.)  The other use for them they are really great for is for reliably grounding small, delicate parts.  (Such as small, light aluminum parts that you need to weld.)  I highly recommend designing them so that you can reliably clamp onto one with your ground clamp.Sharpening the "feet" makes them capable of holding pieces that may be setting on surfaces off of completely horizontal better (because I find the sharpened feet can take more lateral/twisting force before the finger slides.)  Although they do require a little more care in handling when the feet are sharpened.If you are making more than one or two, it's nice to have them in different sizes / lengths than all the same, IMO.  Also, its good to not be too concerned about getting all the weight over the head.  The feet need some weight on them too, to help them not slide. Attached Images
Reply:Looks like I have something to make @ work Monday morning Lots better than searching for someone to hold something in place.
Reply:Great  looking usefull tool, think I'll be making a few of those sunday!SA 200square wave 175 proairco 250airco dip pacsouth bend lathemilling machine
Reply:Originally Posted by wrenchitThis is a very simple project and is a big help in welding smaller projects. My dad called it a welders finger, it is a device made to hold small objects while tacking in place. I bought the steel at the scrap yard to make this, it was 3.56 total in price. It frees up a hand so you can hold the gun (mig welder) with both hands to get a straight shot at the place to be welded. its very handy when welding small objects.
Reply:Nice work, I'll plan on adding some to my tool inentory.Gordhttp://gordsgarage.wordpress.com/
Reply:Made myself one today. Very handy, wish I had one years ago.
Reply:Just made a few of these for my workshop after see these.  Handy homemade tool !
Reply:Nice. I'm gonna make me a few. We are on our way to being farmers! Our site is always under construction so check back often for updates.  http://www.philosophyfarmstyle.com/
GMT+8, 2025-12-25 04:13 , Processed in 0.070311 second(s), 18 queries .
