Small Handrail Build
发表于 2021-8-31 23:43:54 | 显示全部楼层 |阅读模式
This small handrail was built for a small 2 step stair set. Im not sure if code requires a rail for that little steps but the customer wanted one. I don't have to many pics because i forgot to take them as the project went on. This was the first project to test out the miller maxstar 150stl. Call me crazy, but i tigged the whole thing. It was alittle tricky tacking the balusters in by myself using tig. On to the buildMaterials,2'' flat bar1''x 1/8'' square tube3/16'' plate1/2'' twisted balusters1''x1/2''x1/8'' channelMachine,Miller maxstar 150stl with pedal, running on 230v set at max 150 amps, used pedal from there. Great  little tig machine.Layout, use the floor, the way i was taughtThe helping handBalusters all welded in, spacing 4'', getting ready to fit on the base platesBase plates welded onAll done!! Rail top length was made sticking out alittle longer, as thats what they wanted. Ready for primer.Thanks for lookingYa gotta spend money to make money!
Reply:Yea, your crazy.  Looks great man, thats how I lay them out too. You painting it?You have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
Reply:Nice rail!  Did you fab the bausters yourself? If so I think you found your calling.StephenMillermatic 251Miller Syncrowave 200Miller 30A SpoolgunHypertherm Powermax 30Etc., etc., etc.............Cancer Sucks!
Reply:looks real good man, I like it.
Reply:Originally Posted by goinssrNice rail!  Did you fab the bausters yourself? If so I think you found your calling.
Reply:Originally Posted by jreynoldsweldingYea, your crazy.  Looks great man, thats how I lay them out too. You painting it?
Reply:Originally Posted by welderShaneJr,Thanks, yea im just primering it and they said they would paint it their color. I actually made two of them. I'll post a pic of the finished rails. Looks like i just got a call and will be back to welding full time again starting jan, 3 being laid-off for 6 months wasnt too fun. If i had more years experience it would a been a great time to try to go out on my own.
Reply:Nice rail.     I see you got a foot pedal.  I purchased one from ssc.  I never use mine, though.
Reply:Originally Posted by tapwelderNice rail.     I see you got a foot pedal.  I purchased one from ssc.  I never use mine, though.
Reply:I used similar pickets on this project it turned out ok. Attached Images
Reply:nice work
Reply:All primered and done!Ya gotta spend money to make money!
Reply:sexy  nice jobDaye
GMT+8, 2025-12-25 06:14 , Processed in 0.100361 second(s), 18 queries .
