查看: 13|回复: 0
Loss of power
发表于 2021-8-31 23:43:41 | 显示全部楼层 |阅读模式
--------------------------------------------------------------------------------I have a Clarke 180 EN Mig welder and am not sure what is wrong with the welder. I was welding recently and everything working correctly when it "lost power". It went from laying down a nice weld to not having enough power to start a puddle. I've adjusted the power settings and the power adjusts proportionally to the settings but even at the highest setting all I get is "popping" and no weld penetration. Any help is appreciated..Thanks
Reply:Are both legs of your 220v power working, or did one side of the breaker blow?Loose power wire connection inside the plug or machine?Loose ground cable connection inside the machine or at the clamp?Torch fully seated and tightened down in the wire drive housing?MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-25 07:57 , Processed in 0.104721 second(s), 18 queries .
