Some Builtup Welds
发表于 2021-8-31 23:43:40 | 显示全部楼层 |阅读模式
The bumper is finally almost done.  Weather and other stuff has gotten in the way.The built up welds are 4 pass welds.  I like the 4 pass weld better than a 3 pass weld.  For me at least, it gives a better profile.All that's left is to attach the D-rings, and cap the ends.  I gave up on fancy design because I just need the truck back in serviceVery heavy welds  Truck will probably disintegrate before the welds pull out Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:And one more for luck Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersamm........................I gave up on fancy design because I just need the truck back in service...................
Reply:Needs some gussets, somewhere.  Just because.    The best laid schemes ... Gang oft agley ...
Reply:Any left over yellow paint for the bumper?
Reply:.He's not allowed to install it now; it hasn't been approved by his Dog yet!
Reply:lookin' good, samm. i think it'll work fine for ya.as i said before, it's your cow so you milk however ya want.                          mikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:welds look a bit undersized
Reply:i would say where is the big weavy cap?
Reply:Holly smacker, what's that bumper weigh?  Got a 454 in that truck??
Reply:for what you are using it for I would say abit over kill great work I love over kill Just abit of criticism  here but the welds on those engineered lugs could you not have just continued the weld on round the corner and over lapped at the ends instead of patching from one side to another? Just my opinion but for what you using it for it will be fine.If you was going to lift a load upwards of 5k lbs make sure you over lap the welds with out patch works lolI personally like though good jobBoilermakers local 687looking for a place to put your website try this site out www.buzzhostingservices.comenter this promotional code in and get 50% off for life on our ratescode: Boilermakers
Reply:Very nice samm. 7018? 1/8" or 5/32"? Any good places to get those weld on D rings cheap?"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by Stick-manVery nice samm. 7018? 1/8" or 5/32"? Any good places to get those weld on D rings cheap?
Reply:[QUOTE= Any good places to get those weld on D rings cheap?[/QUOTE]I've got a local place that's pretty cheap and that's before my 50% discount that I get. They add up fast on shipping because of weight so i would prolly find them localMillermatic DVIMillermatic 251Older buzz box Cheap 120 welder
Reply:Those welds look great. Nice bumper! Those D-rings can be found at mose local farm and ranch stores. Atwoods, Tractor Supply Co. ETC.
GMT+8, 2025-12-25 06:14 , Processed in 0.103818 second(s), 18 queries .
