Hey dere;I want to extend the width of the foot rests on this Simplicity by 6 - 12" . So I am asking others their ideas as to how they done it, what they used, etc.Tanks Attached Images
Reply:i would probably try to run some tubing under the existing step and tie into the frame with. Then run a piece along the outside. Then cap on the outside ends of the tubing. Then cover that in expanded metal. One thing i would watch for is the part circled in yellow it looks a little high and when the decks raised all the way up it might hit.Hope this helpsRyan Attached Images_______________________OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
Reply:Hey Ryah;Thanks for the tips, sounds good. What is the expanded metal you talk about?All the best Originally Posted by trouble007i would probably try to run some tubing under the existing step and tie into the frame with. Then run a piece along the outside. Then cap on the outside ends of the tubing. Then cover that in expanded metal. One thing i would watch for is the part circled in yellow it looks a little high and when the decks raised all the way up it might hit.Hope this helpsRyan
Reply:http://t0.gstatic.com/images?q=tbn:z...l-0122.jpg&t=1 thats what expanded metal looks like and should be available at your local metal supplier_______________________OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
Reply:Even Lowes and Home Depot have a small stock of expanded metal in their rod, tube, and sheet area.John
Reply:Horvik:Instead of the expanded metal, I would use diamond plate. It's used for this thing on boat trailers, trucks, etc. and gives a really nice finish. Also, you don't have to cap the ends like you do with expanded metal screen. I would simply cut it to the size you need and weld it over the existing foot rest, using the existing one as your structural support.Good luck and post pics.Sign on East Texas payphone: Calls to God 40 cents......it's a local call...
Reply:Horvik,I may have the perfect material for you. I came across this raised expanded metal last week for free at a site I was visiting. I have no use for it (yet) but took it anyway because of the "give-away pricing". It's 16ga that measures 12" wide by 2.5" tall and is galvanized. all together I have 32 linear feet of it. I'll cut you 2 pieces and mail it to you for the cost of shipping if you're interested. Attached Images
Reply:Originally Posted by markfugaHorvik,I may have the perfect material for you. I came across this raised expanded metal last week for free at a site I was visiting. I have no use for it (yet) but took it anyway because of the "give-away pricing". It's 16ga that measures 12" wide by 2.5" tall and is galvanized. all together I have 32 linear feet of it. I'll cut you 2 pieces and mail it to you for the cost of shipping if you're interested. |
