Hydraulic Cylinder Replacement. Cardboard Baler.
发表于 2021-8-31 23:43:36 | 显示全部楼层 |阅读模式
Fun 4 hr call. Had to take the blade out of the machine and beat it outside to get the cylider out. Put the new one in and she running good. Thought I would share. Attached ImagesYou have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
Reply:You do a lot of baler work? As I recall this is your 2nd baler related post. Looks like fun....I can remember in the 7th grade my mom said "people will offer you drugs" by the 10th grade I was like, "where the hell are these people?"
Reply:That looks like a Wal-Mart Store, with a 60"  J.V. (cram-a-lot) Baler.   Who dispatches you guys J.V. Direct???
Reply:Originally Posted by joefitzYou do a lot of baler work? As I recall this is your 2nd baler related post. Looks like fun....
Reply:I have heard of several baler accidents around here, usually involves new employees not familiar with equipment.  gotta be careful around all the hydraulic muscle.  ralph
Reply:I'm sure it's all been handled, but what I wonder about is that the replacement cylinder appears to have a larger bore diameter than the original. If that's so, and if system pressure isn't reset, that could make for a baler buster.Good Luck
Reply:Same size Cylinder, 60".You have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
Reply:Not the length but the diameter, which in the picture appears to be larger; maybe it's not.Anyway, more piston area would dramatically increase force, possibly beyond the frame's capacity. Not trying stick my nose in too far, or do the parts man's job, just something I noticed.Good Luck
Reply:What happened to the first cylinder? Worn, leaking piston? Cavitation (I'd expect that in the pump, not the cylinder), rust from condensation and poor maintenance? Just curious.BTW, I was waiting to see a HAY BALER!
Reply:Same diameter also. The cylinder failed at the weld. Where it welds to the square plate, I will post a picture of the broken cylinder later today.You have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
GMT+8, 2025-12-25 06:14 , Processed in 0.123117 second(s), 18 queries .
