Opinion
发表于 2021-8-31 23:43:35 | 显示全部楼层 |阅读模式
Is this a POS that I should steer clear of?http://www.ebay.com/itm/Craftsman-Ar...item58958499bf"Never mistake education for intelligence."AIRCO Oxy/AccMiller Thunderbolt
Reply:look at the plastic stinger thats brokendont steer clear of it     drive over it
Reply:Are u stuck with 120v ac power?   A HF welder will work just as good, prob even get it for less and get 2 yr exchange warranty.     95 amps is pretty limiting.  If u can get to 140ish you will do much better as that will run most 1/8" rod...Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I'd keep looking on CL even though you got burned recently. If you aren't using a CL aggregator like Searchtempest, Crazedlist or some other, you probably want to try one. It will expand your search radius.I like to set my distance at 200 miles, and use "welder" as my search term. This picks up a lot if poorly worded adds that you might miss otherwise, and then I sort the list manually. 90% of the time unless I'm looking for a specific item, I seldom go far enough down the list to be more than a 45 min drive away, but some times you spot  a real hidden gem out in the boonies..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:There are some great mobile apps for CL too.  If u want that awesome deal u need to use one and be the first to contact the seller.  Usually that means the fcirst 15-30 minutes of the time it posts.   If its on CL for more than a few days its priced too high for the current market.     Offer what u r willing to pay then when declined,  follow up a few weeks later when its still on cL and make same offer...Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Originally Posted by DSWI'd keep looking on CL even though you got burned recently. If you aren't using a CL aggregator like Searchtempest, Crazedlist or some other, you probably want to try one. It will expand your search radius.I like to set my distance at 200 miles, and use "welder" as my search term. This picks up a lot if poorly worded adds that you might miss otherwise, and then I sort the list manually. 90% of the time unless I'm looking for a specific item, I seldom go far enough down the list to be more than a 45 min drive away, but some times you spot  a real hidden gem out in the boonies.
GMT+8, 2025-12-25 06:13 , Processed in 0.089143 second(s), 18 queries .
